RandomChaos
So, tried flying my Versa Wing blunt nose today for the first time. I was going to use a prop-saver, but it caused some nasty vibrations at anything over 1/4 throttle. I ended up hard mounting the prop with a standard collar, and took her for a spin!
The good, it responded to my inputs.
The bad, I guess a 4000 mah battery was too much weight for the plane? Using a 1300kv hextronic with an 8x3.8 prop seemed to give it some thrust at full throttle, enough I thought for a hand launch. After 3 tries though, I am guessing its not, as it would just nose dive at full throttle, lots of up elevator, and even a little tail heavy. Was going to switch to my 2200 mah battery and try to get it balanced to see if it did any better, but ran into a big issue...
The really bad, the pusher firewall I created out of 3/32 balsa wood snapped. Now I'm kind of at a loss on how to fix it. Its glued down REAL good, so not sure I can even get the mount out to try a new one without destroying the blunt nose.
Attached is a photo of whats left, any suggestions? I am thinking maybe cutting out 2 square pieces of balsa wood and bolting the motor to them, while sandwiching whats left of the mount to hold it in place, and some glue?
