Just to be certain that we're using the same terms, since I'm new to quads with a "brain"... for me, as someone who comes from fixed wing flying, failsafe is something that happens when the receiver stops receiving a signal from the radio -- having flown out of range, or the Tx died, etc, right? Or is it an "Oh Crap" button/switch that you activate if something goes wrong?
With my frsky X4R/SB RX, I set a custom failsafe mix to put it in horizon mode (hopefully to right it up) and then cut throttle.
Is that the same as just flipping a pre-assigned switch to put it into horizon mode (I have a 3-position switch, for Acro, Angle and Horizon modes) and then chopping the throttle?
On the flip1.5, I just have it cut throttle -- the default is to sort of "autoland" with a minimum throttle run over a time constant. I set the throttle to zero and the time constant to zero as well.
So, basically, with your setup, it would simply kill the throttle, and drop out of the sky?
What wasn't mentioned on the flitetest build video for the electrohub/flip1.5 build, but is talked about in other videos, is dynamic balancing:
http://flitetest.com/articles/Laser_Balancing_Props
I've seen that video, and I don't see how anything they did served to balance the
motors. The laser showed that the motor and prop, as a
system, was improperly balanced, but adding/removing tape from the prop did not balance the motor, or the prop, it balanced the system as a whole. If a new prop is needed, you couldn't simply add a new balanced prop, you'd have to do the whole laser balancing process again, which doesn't seem like an easy thing to do in the field.
Is there a way to balance the motor itself? I've seen a few Youtube videos where an iPhone is used to measure the vibration, and tape is added to the motor, but I don't have an iPhone! That still seems a bit hit and miss, based on the resolution of the iPhone's sensor. I guess I could use the vibration sensor on the MultiWiiConf screen, like you said? I assume the vibration sensor is the white box with the squiggly lines?
