The P36 took to the air last night. Very touchy, loves to hard climb with throttle. Cut the throttle and it glided beautifully. Got a bit far away trying to trim and lost orientation - nose-dived in a spiral from 100'
to not much more than a broken prop and a wrinkled cowl! I do have it on video - I'll get it edited and up hopefully this evening. So now the learning part! I think my dihedral is a bit shallow from the original. I also think my undercamber at the wing tips is a touch small. Is my thinking correct so far as touchy handling / stability? (I also noticed that my build could have been cleaner - the hstab and wings are not perfect 'parallel' - gotta check measurements on the sides on the plan) Then onto the insane desire for it to climb hard. It's not cg - cutting the throttle and gliding in was quite impressive. I tried to get the thrust line right as original, but with foam thicknesses and such it might be off a little.
Going to go over the plans tonight to see. Maybe shim the motor and play with thrust angle? (I've got a bit of right angle now) I've got to recall and watch the video again - it might have wanted to turn left on hard throttle as well. So, to wrap this up - back to the drawing board!
