@flyboa - I keep watching your latest video with the launch - very very nice!
bracesport Legendary member Jun 5, 2019 #161 @flyboa - I keep watching your latest video with the launch - very very nice!
F flyboa Elite member Jun 5, 2019 #162 bracesport said: @flyboa - I keep watching your latest video with the launch - very very nice! Click to expand... @bracesport it does come naturally after a few launches. No need for competition launches. Last edited: Aug 14, 2020
FoamyDM Building Fool-Flying Noob Moderator Jun 6, 2019 #163 This makes me need to get one going... NOW! ugg it will have to wait. till next week
F flyboa Elite member Jun 23, 2019 #164 Rebuilding a DLG. Added another foam leading edge strip which moved top camber back a little. Last edited: Jun 23, 2019
F flyboa Elite member Jun 28, 2019 #165 @bracesport This is an early example of a simple DLG design. Folded wing with straight leading edge and a UMX receiver. Rudder/ Elevator only. Last edited: Nov 18, 2019
bracesport Legendary member Jun 28, 2019 #166 @flyboa - Very simple and very nice - that was a decently lengthy flight - you had a tad of yaw on launch that is not there with your current ships?
F flyboa Elite member Jun 28, 2019 #167 @bracesport This early model had a lot of wing flex and weak servos. Looks like the throwing blade is also missing. I might try to build one like it again with the my current techniques. Should be interesting.
bracesport Legendary member Jun 28, 2019 #168 I will at least build a fuse next week - the tail is new for me so I need to adapt! What hinge tape do you use?
F flyboa Elite member Jun 28, 2019 #169 bracesport said: What hinge tape do you use? Click to expand... @bracesport I had to experiment with different brands of transparent tape and ended up using Walmart brand.
bracesport Legendary member Jun 28, 2019 #170 Recently I used regular packing tape from the wing covering - I taped both sides then slit the join every few centimetres to reduce the hinge force.
bracesport Legendary member Jun 28, 2019 #171 I am quite exited to go to 1.5m and try and replicate your experience! Do you have any on 4 servos?
F flyboa Elite member Jun 28, 2019 #172 I did make 4 servo versions which does give extra functionality. But for simplicity I prefer the 3 servo setup for now.
F flyboa Elite member Jun 29, 2019 #173 @bracesport wing panels cut and enough left over for flaperons. Clear packing tape covering will add 12g to wing. Last edited: Jul 12, 2019
F flyboa Elite member Jun 30, 2019 #175 Wing complete. 93g. Heavier than the white uncovered wing (70g). The black paper peels very easy. Last edited: Jul 12, 2019
bracesport Legendary member Jun 30, 2019 #176 @flyboa - this looks like no front caps - just laminated and sanded? Ailerons are bottom taped? I use Adams Ready Board - white paper barely holds on!
F flyboa Elite member Jun 30, 2019 #177 @bracesport I did use LE caps and cut back the top covering. Sanded a sharper LE now. I would not recommend using the black DTFB. Flexes too much and paper does not adhere very well. Last edited: Jul 12, 2019
bracesport Legendary member Jun 30, 2019 #178 I have run out of FB - so I need to plan a trip to the store!
F flyboa Elite member Jul 15, 2019 #179 New 1m DLG wings. It has been awhile since I built a small DLG. Last edited: Aug 14, 2020
bracesport Legendary member Jul 15, 2019 #180 while you go smaller - I go bigger - I am going to tackle the 1.5m wing today!
