Sotm
With Ben's permission I am doing a build log of his F4 Phantom. I have made some minor changes also.
F4 dual 70mm Build:
I started the build by printing all the PDF's as tiled PDFs with Adobe Reader on to gray card stock. Cut and taped each 30x20 sheet together (8 tiles each). Then I cut out the parts and transferred to foam board carefully marking all Cut, Score, Bend and reference lines onto the foam board. Don't forget to transfer the panel markings (1F, 3R, 5, 6,etc.) that Ben placed on the pieces also and make sure you put them in the same place he did, they are there to help orient the pieces together later. After cutting out the foam board parts I did a lot of trial and error part fitting trying to figure out the orientation of the pieces. Did some messaging with Ben also via the Flite Test build Blog. I choose to do retracts also and so while I waited for them to be delivered I started on the fuselage parts and ducts.
Pay attention to the type of fold joint called for on the parts. Some are "A" and some are "B" and they make a difference.
While building the ducts I remember Ben said he was going to move the EDFs back to help with battery placement. So after the EDF cradles were assembled I placed them into the current position slots in the ducts, then removed and moved to the back slot and marked for a new back slot. A better way would be to only cut out the back slot and use it and the cradle to mark a new back slot making this one the front slot. Then you wouldn't have to plug a hole! This will move the EDFs back and inch and three-quarters and should be plenty to help battery placement. You then will need to fill the front slot with a glued in piece of foam board. Make sure the inside of the duct is smooth so as not to disturb airflow to the EDFs. See picture for details.
Don't close the top of the nose area until you finish the nose gear installation and the nose wheel steering servo. It would be very hard to work on if you do.
I'll be continuing the build. Keep watching.
F4 dual 70mm Build:
