FUUUUUUUUUUUUUUUUUU!!!!
so I got my package of fine solder tools today, tip activator, metal brush tip cleaner that also acts as activator and both will retin the tip. flux pen. desolder wick(which was absolutely useless, even at the highest temp on my solder station which should be 450-490 ish, I'm thinking it's because of the damn lead free solder they use in production today.
so I get to work, give up on the wick and just figure I'll get the old antenna wire off before I try to get rid of the old tin, so I start with the biggest(ground) solder, and it melts right away without the wick of course my iron is still at the hottest. and as I carefully lift it lose, not only does it come lose, I manage to get the whole pathway on the board from the signal solder point to the chip...OMG!!!
Off to BoltRC to order a new backboard I guess, I'm not sure if anyone else have them and he has them pre soldered.
Be warned if you're soldering those though, those patches are extremely thin and will rip loose with the slightest touch.
