So I will start with the problem. I am using the Taranis X9D with a D4R-ii receiver and am having horrible range issues. I am getting sub 100 yards of range and using the range tester I get a few feet before the lights go red on the receiver.
Its been a semi ongoing problem throughout the summer and I hadn't really attempted to fix it until recently. My first thought was that it was because I had a damaged antenna on the receiver. So I replaced that and it had no affect on the range of the quad. Next thought was perhaps a damaged receiver from a crash. Bought a new receiver to test and same results. Next thought was bad power distribution. So I took off the receiver and used a battery to power it, and the same poor range resulted. Basically I am out of ideas at this point, maybe I am missing a function on the radio itself or there is some internal damage for some unknown reason. I do believe the transmitter battery is adequately charged so I don't think that is the problem. But if you guys have any ideas I am all ears.
