Hey everyone!
I need a hand with programming my transmitter for use with the FT Twin Sparrow. I already managed to program the rear V-Tail servos correctly, and now all I need to do is set it up for vector thrust. I am using the FlySky FS-i6s with the FS-i6b receiver. I have used both models before for a quadcopter build and I am reusing the same controller here using model memory for the Twin Sparrow. It has the same settings as the FS-i6, so if anyone has set up vector thrust on that, the same settings apply here. Thanks!
#2
i think you mean differential thrust where one motor speeds up and the other slows down? if so, make a mix. this works for my seaduck.
mix1on
master 3 slave 6
pos and neg 100%
mix2on
master 4 slave 3
pos and neg -100%
mix 3 on
master 4 slave 6
pos and neg 100%
#3
mix1on
master 3 slave 6
pos and neg 100%
mix2on
master 4 slave 3
pos and neg -100%
mix 3 on
master 4 slave 6
pos and neg 100%
Thanks so much! I'll have to see if this works. I'm pretty sure that thats what I'm going to need. Having some problems with either my gremlin motors or my attached esc's. Gotta troublshoot those first.
