TexasPilot71
Hi guys! And HELP!!
I built the FT Duster using the speed build kit and the power package PROVIDED BY FLITE TEST. This power package includes the EMax 2215/9 motor and a 10 x 4.7 prop. I know Flite Test calls for a 9x6 prop, but this power package was provided by Flite Test and included the larger prop. Additionally, the website specs show it should work with a 10 x 4.7 prop http://www.emaxmodel.com/views.asp?hw_id=16
However, the motor gets extremely hot after only a minute, smells like it's burning, heats the battery up, and depletes the battery in a matter of about 3 minutes. I've tried a couple different brand 1300 mAh 30C batteries with the same result. I even purchased another identical motor believing the motor was bad. SAME RESULT.
I am very frustrated and don't understand why it's doing this. The only think I haven't changed out is the ESC, but I doubt that's the problem. By the way, it swings an 8 inch prop no problem. I don't have the 9 inch to test.
Can anybody help? Thank you!
Attached photo shows watt meter after either 1.5 minutes or 2 minutes, I believe [URL=http://s287.photobucket.com/user/ZippinZim/media/Mobile%20Uploads/2015-05/20150504_151641.jpg.html] [/URL]
