FT explorer tail heavy
Chappie66
A 3 channel plane needs a bit of dihedral, to help them turn better. In a 4 channel plane you will not see much of a difference with or without the dihedral.
There is not much difference between a 3 & 4 channel plane. The ailerons can have more authority, easy fix, just turn down the throws until you get used to them. Then crank them up so you can have some fun.
You could always add polyhedral to the Armin wing.
The amount of dihedral will determine the inherent stability along the roll axis, or self-righting characteristics. Trainers usually carry an amount of dihedral for this reason.
4U2NVME
Ok here is the new and less improved bottle neck explorer :). I extended out the front by making the battery tray larger, as well as making the nose a bit longer. Put the Popsicle sticks in there to both help line up the new portion of the tray I was putting on, as well as giving it some extra strength for a hard landing or two... ( Its not a matter of if you will crash, but when I have learned )
I now need to build an extension XT60 connector battery wire, dial in my throws, put in some expo, give me 3 different flight envelopes to fly with then fly it out... thanks again for the suggestions on how to hopefully make this a successful maiden.. Trying to add new skills with each new build. This one is a far cry from my first build... hope she has many successful flights!!
4U2NVME
Hmmmmm.... This thread kinda makes me want to build an explorer.
What they hey I screwed up.. please help kinda thread?
This hopefully will become my FPV based plane, or if I destroy it, another one. Then I want to upgrade it, put on a FC, and add 4 motors and have it switch between normal flight and drone mode... check this out.. VTOL Explorer
I also want to learn to program a FC that will give me Return to Home, Maybe hold position, On screen display and telemetry... I have so many wants out of this platform, but I think it can deliver... but first....learn to fly it ;)
-NV
rmzalbar
My Explorer was tail-heavy too. I initially shoved the tailboom further in, but it wasn't really enough to eliminate ballast entirely, plus it didn't fly as efficiently that way. Extending the nose was the way to go. I lengthened mine by 3" before the bottle neck. I did that because it gave me more room to put things in the nose, such as a camera; the bottleneck area is barely tall enough to hold the battery alone. I love the method you used to graft an extension to the battery platform, very elegant and pleasing, and a simple trace. I didn't think of that, and just did a square cut.
4U2NVME
Hey all....ok I did my maiden today!!! I have full video reel later... but I want to post a few pics in the mean time...
its shall be titled from "Here to There" What I like you all to do is tell me, guess, or postulate how I got there.... There were many attempts to get from Here to There, it was not a 1 time trip.... detail my Journey in your own words.. have fun with it if you like, or make it a teaching moment if you like its up to you!!
Video to follow and some of my thoughts and learnings..
Ok First the "Here" Picture :) This is where my journey began....
About 15 minutes later here is my "There" picture.
evranch
Wing split with no other damage, no crumpled nose, tailplane looks good. If you had ailerons I'd say you overcorrected on final and dipped a wing. With rudder only... and that wing that doesn't look like it has any dihedral from here, I'm guessing you lost roll control and knife edged it in. Which wing design is that?
4U2NVME
Its the Armin wing...there is some nose damage, I crumpled the battery tray a bit.. that will need a rebuild..or popsicle sticks to fix
evranch
Well it looks like you didn't land directly on the nose, at least :) Looks like an easy fix. The Armin wing is a flat wing, so that's my guess. Without dihedral it won't level the wings by itself, so once you take on a little unwanted roll it will get worse and worse until you find the ground.
Jeffer949
I'm guessing aggressive dive into aggressive pull out. wing could not support the load and broke. Sound like I have experience? Well its because I did the same thing. My new wing has a 1/8"x1/4" about 20 inches long glued to the back edge of the foam spar for support inside the wing.
How do you fly a 3 channel plane with out dihedral?
quorneng
If the wing really has no dihedral and you are flying RET (rudder,elevator.throttle) only you making things quite a bit more difficult to control. Not that it can't be flown like that but the rudder control will tend to be 'lazy' and thus has to be input as a wing starts to dip not after it has!
Give the rebuilt wing generous dihedral and not only will the rudder have much more roll authority but at modest bank angles it will even be self levelling. Rudder to make it bank and turn, centre the stick (or just let it go!) and it will return to straight and level flight by itself!
rmzalbar
15 minutes? I'd guess your battery went flat and you dropped out of sight somewhere and nosed in. My second guess is you went for the power-dive-loop and overstressed the wing.
