After the HUGE success of the FT Mini Guinea we have decided to release it's big brother, the FT Guinea Pig!
If you'd like to build one of these with us you can download the plans below, trace them out on foamboard and get cutting!
FREE PLANS
Or if you would like to support us (and save yourself a ton of time) you can pick up a Speed Build Kit!
For the first time ever we can say that if you need a solution for your electronics, WE HAVE THEM!!
We now offer Power Packs directly from us, so no more scouring the internet for your parts!
If are are picking up a Speed Build Kit there is also an option to include the required Power Pack. It will automatically add it to your total.
So now that you can EASILY and SIMPLY get your electronics, you'll need to put them to good use!
For this twin you will need to build two Power Pods. If you've never built one of our swappable kits before, the Power Pod is a quick way to move your electronics from kit to kit.
The entire pod can be removed and slotted into another swappable. No need to buy multiple electronics.
We recommend building the two Power Pods first. You can see the Power Pod build video below!
[COLOR=#000000][FONT=sans-serif][IMG]http://assets.flitetest.com/article_images/medium/guineabuild-5-png_1424198523.jpg[/IMG][/FONT][/COLOR]
[COLOR=#000000][FONT=sans-serif]First we'll work on the wings.[/FONT][/COLOR]
[COLOR=#000000][FONT=sans-serif][IMG]http://assets.flitetest.com/article_images/medium/guineabuild-6-png_1424198439.jpg[/IMG][/FONT][/COLOR]
[COLOR=#000000][FONT=sans-serif]Step one is to cut a double bevel. Use a boxcutter or razorblade to cut a little beyond a 45° angle on both the aileron...[/FONT][/COLOR]
[COLOR=#000000][FONT=sans-serif][IMG]http://assets.flitetest.com/article_images/medium/guineabuild-7-png_1424198541.jpg[/IMG][/FONT][/COLOR]
[COLOR=#000000][FONT=sans-serif]...and the leading edge. [/FONT][/COLOR]
[COLOR=#000000][FONT=sans-serif][IMG]http://assets.flitetest.com/article_images/medium/guineabuild-8-png_1424198550.jpg[/IMG][/FONT][/COLOR]
[COLOR=#000000][FONT=sans-serif]To join the wing halves start with a small piece of tape just to hold them together...[/FONT][/COLOR]
[COLOR=#000000][FONT=sans-serif][IMG]http://assets.flitetest.com/article_images/medium/guineabuild-9-png_1424198467.jpg[/IMG][/FONT][/COLOR]
[COLOR=#000000][FONT=sans-serif]...then apply a larger piece of packing tape across the center. [/FONT][/COLOR]
[COLOR=#000000][FONT=sans-serif][IMG]http://assets.flitetest.com/article_images/medium/guineabuild-10-png_1424198571.jpg[/IMG][/FONT][/COLOR]
[COLOR=#000000][FONT=sans-serif]Now when you flip the wing over there is a hinge. [/FONT][/COLOR]
[COLOR=#000000][FONT=sans-serif][IMG]http://assets.flitetest.com/article_images/medium/guineabuild-11-png_1424198485.jpg[/IMG][/FONT][/COLOR]
[COLOR=#000000][FONT=sans-serif]Fill that hinge with some hot glue
