I got some FPV equipment for Christmas. I thought that I would build a Versa wing "bigger" to take the extra weight.
I printed the plans out at 120% and added a center pod to take the extra equipment. I did the maiden flight today and it worked out quite well. Very cold out today at -15 so it was a quick flight. The trim was way off so it always wanted to go down. I will need to adjust the elevons or possibly the CG. I will play with it a little bit. It turned out to be 54" wing span. Powered with a RC Timer 2212/6 2200kv motor, 7x3 master airscrew prop, 30 amp Turnigy Plush ESC. Set up for two 3s 2200mah batteries.
