PS. Has anyone found retracts that will actually fit inside the wing? I bought some HobbyKing retracts, but they'd be a really tight fit. I've seen the ones on the FT site using regular servos, but I'm thinking a rough landing would kill those servos pretty quick.
Owen
I don't know what the dimensions are, but I had my eye on these: http://www.motionrc.com/servoless-e-retract-with-metal-trunnions-set-of-2/
They are actually the units used in the Art-Tech P-51 I'm gonna steal the prop from too. It's the same span (a tad shorter actually), so I can't imagine that the wing would be much thicker. You might have to cut into the upper surface a little, but you can just reinforce around it.
The bigger hurdle I see with doing proper retracts is where the wheels go, because they don't just go into the wing; they actually go up under the fuselage a bit, so we have to actually cut into the fuse sides a little. Again, probably doable, but will need some reinforcement.
