The speed build kit has foam piece guides that hold the push rods against the inside of the fuselage (see the red-framed pictures in the article accompanying the build video) -- which I used in my first Old Fogey. Using coffee stirrers, one would only have to use small (maybe 1" sections) glued to the inside of the fuselage every few inches to accomplish the same thing.
On my second (scratch build) Fogey, I took a different approach. I used scrap pieces of foam across the inside of the fuselage -- these had small holes poked in them with short pieces of coffee stirrers to act as guides (see the attached pictures). I preferred this over the side-mount as it gave them more of a straight line from the servos to control horns -- less binding.
Originally, I only had two foam guide "bulkheads" with coffee stirrer guides. This permitted too much flexing of the FT-supplied wires, so I added two more guides -- just a piece of foam board with slots cut in them to slide over the already-installed wires.
Either way, you don't need a continuous run of tubing to provide adequate support for the push rods -- every few inches will suffice quite well.
