The new plans are great! I used them to build my second Old Fogey.
But, I also made a few modifications to try to incorporate some of the newer techniques FT has started using. I used the servo tray, with the legs twice as long, and wrapped them around as a 'C' fold, making a nice doubler for the nose. I will try to post a pic.
I also cut down another servo tray to the height of a servo and glued in down to the bottom of the fuselage to make the control wires move straight back and forth. I use surveyors flags for my wire, so it is a little stiffer than piano wire.
Lastly, I don't use the front skewers anymore. I run a bamboo skewer through the side. With triple walls, this works nicely, even after several crashes, as you'll see in the pics.
I know it looks pretty rough, but if you had seen the crashes,... I'm trying to learn to fly, and I don't have any routine help. So, as Ferdinand the duck from Babe says, "I'm all I've got, [honk]"
Now, has anyone come up with a better way to attach the horizontal stabilizer? I've had to add tape to both of mine. It's just paper glued to paper, and it hangs on the bottom side, so there's not much to hold it.
