Sero
No this does not sound like flutter, but it does sound like dutch roll. I have had bad luck with the tip plates you are using personally. They are not going to help the dutch roll since they are not aft of the center of lift. Purely drooped tips have helped my previous efforts but I think your fix might be a dorsal fin (see cessna 172 vertical stab) or a ventral fin or fins (see Citation XLS or Citation Latitude) these may help the stability and control.
All of these installations were to reduce dutch roll or yaw issues. The dorsal fin is the easy one the ventrals need to be angled so as to not cause pitch issues.
Once agin just thoughts on things to try.
Thanks Jeff!
Yes my research had shown a ventral fin should help and probably is the easiest fix to try. I noticed the single fin like on the MIG-23 and various others vs double fins such as the Citations you posted. To keep things simple I was planning on trying the single fin. Are the double fins that much more effective and do you know why they are cambered out?
Steve
