Frame: FT Simple soarer (speed build) 3ch.
Prop: 9x4.7sf
Power plant: Emax 2280kv (plans call for 1300kv)
Power source: Kinexsis 800mAh 2S
Servos: 8.5g
I can not get this thing in the air. I have been fighting this thing for weeks now.
The last time it crashed I thought I was going to jump on it and stomp the ever-lovin servos out of it!
---EXAMPLES---
No wind, Gliding, No input given. I tossed it and got a gentle, nice, (dare I say) perfect glide. So by this we know CG is not an issue.
-no video-
Strong wing 5-10 knts, Gliding, No input given, 10' off my hand it noses up, stalls, gets blown backwards and belly lands, no damage.
https://youtu.be/2qe5PSV4zcU
#2
Strong wing 5-10 knts 1/2 throttle Thrust Angle 4-1/2 degrees down. 15' off my hand it noses up, stalls, noses down, face plants, crushes fuselage and increases TA to about 10 degrees.
https://youtu.be/r7l07lhdXuU
#3
Strong wing 5-10 knts full throttle, Thrust Angle about 10 degrees down. 20' off my hand it noses up higher, stalls, noses down, face plants.
https://youtu.be/BUyLl66udeo
>THROWS HANDS UP IN THE AIR<
So I started with 1/2 power in #2 video the Thrust Angle is at 4-1/2 degrees down.
(I know I cut it with a miter saw)
After the face plant in video #2 the Thrust Angle is closer to 10 degrees down.
I had been using a 5045 prop with exact same results.
The 9x4.7 is new, I was hoping that would get me in the air.
In my head I thought if the 9x4.7sf prop did not help I would try increasing the TA but before I could get it to the bench What ever is wrong, Newtons 3rd law and Gravity did the work for me after video #2 and the 1/2 throttle face plant.
saved me some work there
So friends, what now/next?
?Smaller motor? is all I can think of, but I'm not throwing all 2280kv at it.
I'm pretty frustrated,
I could use some help from my friends.
(So we never met and I have like 3 posts, dont worry I'm volunteering @ FF-E I'll meet you there.)
Prop: 9x4.7sf
Servos: 8.5g
---EXAMPLES---
-no video-
#2
#3
