Little something I noticed in the vid was David using a cheap utility blade while Josh has usually been using #11's. Even heard Josh comment on the cost savings and how much longer the utilities stay sharp cutting foam.
Funny thing about that...I was a huge #11 fan for a LONG time - but when I started building foamies I switched to utility blades because, well honestly because everyone in town was out of stock of #11's
But I kept hearing about how utility blades supposedly stay sharp longer against foam and they cost a lot less. So picked up a 100 of them and have been quite happy with them. Being so cheap it's no big deal to keep switching to a new blade more often than I used to. (I would keep cutting with a #11 well past when I should have switched because every time I'd switch blades I'd hear a cash register in my head.)
But I've had a hard time doing the little alignment notches with utility blades so I dug the old xacto out today to cut some parts of my spitfire. And man, I'm suddenly hooked on the #11's again. Staying sharp way longer than the utilities I've been using and even when a little dull cutting nicer than a fresh utility.
Still like the utility blades for score cuts since I can set it to it's lowest setting and drag it along my ruler to just cut the paper. And still like them for big rough cuts. But I actually enjoyed cutting my bevels with the #11 today instead of it feeling like a chore.
I swear my utility blades seemed sharper out of the package a few weeks ago...today even a fresh one I can't seem to get a clean cut. Oh well. Just had to share a little
Got to go finish cutting out my fuselage and then warm up the glue gun!
