Flynn
Ok guys, this is what I have so far. Thanks to Doglover for the original idea!
When you put this thing together, it's a B fold and I would cut the base rounded ends a bit bigger and trim to fit. Or cut one and see if it looks good.
The turtle deck, fold the middle part over and get a good placement on the ribs. If you cut the turtle deck long on the ends, you will be able to trim it with scissors
Glue along the top part. You can glue the middle part first, then the front and back
Then I was gluing the front and back sections down. If you leave these long (dotted lines on the plans) you can trim them for a better fit.
Then glue middle section. The front lines up, the back kinda hangs over.
And this is it on the plane.
This is the plan. Print no scale, or check scale on the inch line.
