slarti42uk
Hi all,
I wonder if someone can help me, I decided to add the GoPro to the under side of my storch (6mm depron build), between the wheels and in line with the CG. Balanced out fine and gave an AUW of 1272g (2lb 13oz).
I thought that it would happily carry the extra weight but I found that I just could not get it off the ground. The AUW without the GoPro and case is 1125g and it took off and flew just fine. (I have all the frisky cemetery on board so it's a bit heavy normally)
My power setup is:
Motor: NTM 2826 1200Kv
ESC: HK 30A
Prop: 9x6 APC e
Batt: 2200 25-35c Zippy
Any ideas what the max AUW of this plane would be? Is my power setup too wimpy for the extra weight? I'm wondering if I just didn't give enough elevator but normally I apply the power and if take to the air with almost not elevator input.
Cheers
My power setup is:
ESC: HK 30A
Prop: 9x6 APC e
Cheers
