Okay I have the plans made up and I can print them out through double cad, but I can't get them into a PDF to share. I tried everything on this forum but can't seem to solve the issue. What would you recommend?
It's pretty simple if you're using my template. In the models tab, arrange your parts how you want in either the full page, tiled section, title pages section, or all of them.
Then you go to the tab that corresponds to where you put your parts. Once you're there, click on file, and print.
Then use your preferred PDF printer application. There are a ton of them out there, PDF Creator, PDF Architect (Great for Full Size Sheets), cutePDF. I think windows 10 even comes with one, Microsoft print to PDF.
For tiled stuff, choose the number of pages you want to print, numbers start at one in the bottom left corner and work their way up. Doublecad is limited to a maximum of 16 tiled pages per set, that's why I stuck 4 sets on my template if you have a lot of parts. The sets can be combined into one PDF file after you're done with your program of choice. PDFSam is a simple one, but if you have PDF architect, it can also do it.
Once you choose the number of pages, hit print. Depending on your PDF creator application, it'l probably bring up a window asking you where you want to save the PDF you just made.
For Full Page stuff, I reccomend having PDF Architect.
Here's the settings I use. Set the pages to 1 to 1, then hit properties and change the paper size, orientation, and quality.
The paper size for my full size sheets is ARCH D, as you can have it printed at that size just about anywhere.
