FT Tiny Trainer and wind
echophone
Yes a stabilizer will help but will not solve the problem. Adding weight will also help. A better solution, build a smaller (shorter) wing. Try removing 10 inches, 5 from each side.
Building wings is always enjoyable. I will give a shorter wing a try and see how it goes. Thanks.
echophone
The MT1806 2280KV will easily cope with a 3s 1000 mAh, but Ive upgraded my last build with the mt2204 2300KV motor its much better for the 4ch version and cheaper too.
What size and pitch of propeller are you using with this set up?
