While rolling down the Soviet/Russian concept plane rabbit hole, I found this beauty.
Ushakov LPL Flying Sub Statistics:
Crew, man. 3
Takeoff mass, kg 15,000
Flight speed, UZ (km/h) 100 (~200)
Flying range, km 800
Ceiling, m 2 500
Quantity and the type of aircraft engines 3 x AM-34
Power on takeoff conditions, hp 3x1200
Submerged Characteristics
Underwater knots 2-3
Submersion depth, m 45
Action radius under water, miles 5-6
Underwater independence, h 48
Duration of sinking, min 1-5
Duration of immersion, min 1-8
Armament:
- 18- in torpedo, pieces. 2
- coaxial machine gun, pieces. 2
Proposal
Year-1940
Speed- 7?(Air)/0(Sub)
Torp 2/1
Model Statistics: (A/F Pack Version)
28" Wingspan
Motors: 2- A Packs + 1-F-Pack.
Estimated Thrust: 360+360+600 =~1320g
Servos: - 6 - 9g Metal Gear (1 for torpedo + 1 for Perscope {and ballast tube}
Battery - 3S 2200mAh
Props - 5" x 4.5 or 5"x3x3
Estimated Weight (without Torpedos): 560g
Wing area: 1.57sf
Wing Loading (without Torpedos) - 19oz./1.57sf or 12oz/sf with is in the glider/trainer portion.
My Goal:
1. Make a model that flies well.
2. Get it to float
3. Make it easy to build
4. Sink it
5. Get it to come back up.
6. Find a way to make the sub part affordable.
I know VERY little about RC Submarines. I have reached out to *the* Bob Martin IE www.RC-SUB.com and on Youtube he's RCSubGuy. This guy has a true passion and talent for submarines. He estimates a larger amount than I have to build this as a submerging vessel. (while I'm still trying to see what I can do to mitigate the Costs.) His sites, encouragement knowledge and thorough videos, should help me know how we can manage this. While a bit discouraged by the cost, I think I could set limitations of the vessel and get away with a less costly setup... but I'm not sure.
While rolling this around in the signup forum thread (linked in blue below), I talked out some feasibility on can a foam plane sink. Some of you might know first hand.
Displacement: 534g
Each foam board displaces 36g of water. My initial design is 4 sheets. (a c-size will take 8 at least)
I will assume the entire plane floods except the cockpit area I would have a watertight container in there.
The size is roughly 6.5x12x5cm or 390 ccm so that means the plane must weigh 534g. (1.2 lbs) for a 3 (4) engine Plane.
Weight: 355 - 560(ish)
5 -9g servos - 45g
4 - 40g motor setups (2205 with 30a ESCs and 5" prop, producing around 1.8kg thrust (for 3 engines)) 120g
8 channel receiver or FC - 10g
4S 1500 - 3500maH battery - 188 - 385g
So I see this as a matter of playing with the WT capsule size VS. Battery or foam load-out. to get things to balance when the plane floods.
Making this plane into a sub can/will include the following challenges:
Now it's time to do it:
Made a first stab at plans are here:
Apparently I'm a sucker for a challenge. I hope you enjoy this thread as I try to make this fly, land and water, sink it and fly it back.
10/10/18 edit
PDF PLANS
Alpha Build plans. base on all the tests, this will Fly. I will make sure to mark the CG distance from Leading edge here when I can measure it.
LPL Flying Sub-Alpha 1 of 4
LPL Flying Sub-Alpha 2 of 4
LPL Flying Sub-Alpha 3 of 4
LPL Flying Sub-Alpha 4 of 4
Note: I had these ready LONG ago based on this first post. I just had NO idea if it would fly. None. (and at the time little confidence.)
Crew, man. 3
Ceiling, m 2 500
Armament:
Proposal
Year-1940
Torp 2/1
28" Wingspan
Wing area: 1.57sf
My Goal:
2. Get it to float
4. Sink it
Displacement: 534g
5 -9g servos - 45g
- The new skills will include building a waterproofed plane.
- Learn how to Minwax a Plane (in and out)
- Learn how to WP Servos.
- Learning how to make a WTC for Subs.
- Building a Sub motor system.
- Learning to Fiberglass, then dissolve the foam inside.
- Building air bloat bags.
- Making Torpedoes.
- Getting a 72-75mHz radio system with 6 channels. (2.4gHz doesn't travel through water)
- Figure out how to use a FC to work it all.
- Learning to design and build and print a 3D printed Plane. (to aid neutral buoyancy, by removing foam which makes traditional )
10/10/18 edit
PDF PLANS
