vhandon
After completing the Grumman S-2 Tracker I realized I had enough time to join the FTFC19 challenge and have something to show at FliteFest Texas. I am a fan of Crimson Skies and wanted to do one of those planes. I settled on the Curtiss-Wright P2 Warhawk and started doing some research. That led me to the Blohm & Voss BV P.170. I decided the design would lean more toward the historical P.170 than the fantastical Warhawk.
The air frame is done and I will add the electronics next week then complete the plans. I did keep the design very simple and it went together relatively easily. I already started the plans and even though I have never created a set before that process is going well. I had a thought today as I was getting ready to create this post, "this is too easy, someone else has to already have done this plane." And I was right. I sorta feel like a heel and unoriginal now but I am still going to complete the build and the plans.
The entire plane is basically modified parts of an FT Tiny Trainer with three mini Power Packs, either A or F. It will only take about a sheet and a half of foam board to build but maybe a little light electronics work if you want differential thrust (i do).
I will go ahead and add the apparently only drawings for this plane along with the a cool Warhawk image.
