That's what I was thinking also. I have a 128GB micro SD card for my digital camera. I think it may record a decent amount of time at 720p. at 1080i I don't think it will stand a chance. I'll look into this more.
Got busy last night with my build on a 75% Polaris. I'll try to get the video stuff more sorted this evening.
Aaaaand... I'm back onto foam supply. I've heard through other online areas that the usual 2" pink (or blue) foam board is becoming quite the hot commodity. Apparently HD does not carry it and Lowe's does not either. There are other 2" thick foam boards but the quality is not very good for our application. I will try to make a stop into my local HD tonight to confirm this. As I understand it is a regional thing due to it not being used much due to the climate. If I cannot source some here I may have to request someone from up north if they can buy a sheet for me. I currently have half of a sheet but its not enough for the entire build. I'll need at least one more.
The good thing is that the foam will not be bearing much of the load for the wings. The spar will be doing that work. The fiberglass will not be doing much either, but I am planning to use epoxy and glass on the root to set the dihedral. I'll blend the seam with poly/babypowder/spackle if the seam is that bad. So, if I have to use the less desirable foam then I can and will make it more of a challenge to work with a new material on-the-fly.
Went to the store... GOT IT!!! only $21 total. About as flat as I could get but manageable. I'm all set.
Also looked into the camera situation. So at 720p I can record 11 hours on the 128GB SD card I have. Pretty sure the battery will not last that long. Then at 1080i I can record nearly 7 hours. Maybe go with 1080i and record for critical stuff? Pretty sure I'll need to charge it overnight too... somewhere.
I received my two Lemon Rx receivers in the mail yesterday. Glass cloth inventory looks good. At this point I think I'm in good shape. I am really looking forward to this build. It is not a typical build for me. I usually choose something that has seen military service and is a bit more "sporty." I want to point this out as this community has been the driving force for this project. The community selected the genre, the subject, and has helped me with the planning and gotten me to maintain the motivation for this project. There is no doubt that this will be an "epic" build at FTFF2015 and I have you all to thank for it.
I look forward to seeing old friends there as well as meeting new ones. Since making the migration over to these forums from others it has been clear that it was the right move for me. I've learned much here and been able to share much with others. I have no doubt that this will become an annual project for me. I look forward to this build and discussing with all of you what will be in store for next year's project as well.
In three weeks from TODAY I will be arriving.
You know, we are only about an hour apart. We should get together some time.
