Time for another swap meet rescue build!
This time it's the classic Dreamer Biplane designed by Jon Foster with plans published in the June 1972 Flying Models Magazine. The specs are 39.5" wingspan, designed for .40 sized glow fuel motor, and 4.5 pounds. The design was later kitted by Gee Bee, and one of those kits was partially built, tossed back in it's box with a ton of little broken balsa bits, stored in an attic for a couple decades, and then sold at an RC auction in 2018 to a sucker... er... enthusiast, which brings us here
A couple beauty shots of what it's supposed to look like...
[EDIT - this is my "pre-maiden" finished biplane
follow us through the rest of the thread to see how it was created! ]
[/EDIT]
When I started researching this kit and discovered it was based on published plans, I had to go looking for the magazine where it was published. Thanks to eBay, I found it
The plans in the article are a little different that what's in the kit - reformatted from one page to two pages, added interplane struts, switched the horizontal slab to a truss style build. As I go along I'm sure I'll find other mods too.
And speaking of the kit, here's what I bought at the auction.
Time to sort out this pile of wood and see what state things are in. Horizontal stabilizer looks good - vertical stabilizer was broken in half along the grain, but easy to glue back together. A little splintering in the wing sheeting to glue back down. Plans are in good shape - a little foldy, but stretched out under a piece of glass nicely.
The bottom wing looks straight and true, with the right amount of dihedral. For some reason the cap strips on the ribs had all been installed, and then ripped off one at a time and tossed back into the box.
Oh well - starting on the bottom of the wing I cut and installed new cap strips. Next I made hatches and installed cross bracing for a dual aileron servo install. Just holes in the hatches now, will turn those into slots with a scroll saw tonight.
Next will be finishing up the aileron servo mounts, cutting the ailerons, holes for hinges, cap ribs at the wing tips, and then the curved wing tips.
Debating if I should stay with the classic rubber band mounting - which is much friendlier to a bumpy landing - or building out some bolt on mounts....
[/EDIT]
