FAI-F1D
Free Flight Indoorist
I built this cute rocket glider a while back, and it flew nicely...
Then I decided to be a stupid idiot and make a bigger one.
Ok, to be a little more serious, here are some details:
Root chord is 10.4", with a 3/8" thick sheet balsa wing for 3.5% airfoil thickness (probably a little on the thin side).
I'm using a fiberglass 29mm motor mount which can fit E-F Estes motors and F-G Aerotech composite motors. Still yet to arrive is a fiberglass nosecone (can't use plastic as the captive nose mount would cause the nose cone to melt from the ejection charge).
Tailboom will be a 1/4" carbon arrow shaft.
Wing area is about 500 sq in. Oh yeah.
Trying to keep the weight under 16 oz. I'm a little worried about that bit. Estes F motors only put out about 5 lb of mean thrust, so the model needs to be kept to about 1 lb for a safe launch. We shall see...
Plan view of this madness:
