TooJung2Die
A 2.4 GHz antenna is only about 1.25" long. If the wire that came off is short then there's no ground. If the wire is longer, say 6", then there is coaxial cable before the antenna at the tip and you need to solder the cable core and ground shield.is there a ground to be concerned about, or can I just solder back on the connector?
