I realized, after installing the battery tray, that I needed to reassemble the entire aircraft and check the CG balance before I cover and paint. I set the Great Planes CG machine at 4 1/8", per instructions, and set the plane upside down on the pads. To my amazment the plane was almost balanced but nose heavy, so I set the radio gear, package and all, on the tail and it balanced perfectly. I did not have the canopy or battery cover on, so I belive they may add weight towards the tail too. Also, once it's covered, painted and hinges epoxied in, that should add tail weight.
So, I like to put the radio gear towards the tail away from the motor, esc and servos, but this may make the plane too tail heavy, but I'm thinking it wont be anything drastic since it's balancing so well at this point. I think it's time to start the final sanding and finishing process. I also have the room to shift the battery 1" forward for a total of 2" fwd or aft of adjustment.
My battery tray design left a nice gap between the wing and tray for the aileron servo wires.
