A little progress on the engine and regulator, though nothing substantial. Firstly, I think this as good as this engine can do inverted. I've given it every bit of help I can here - a regulator, a heavy APC propeller, and even a Saito P2 plug, as I think they hold heat a little better than an OS F. The LSN is still incredibly sensitive, and it still seems like the sweet spot normally present when upright has been outright deleted.
It's idling here, low enough to land (probably) but as you can see in the video it picks up from about 2700 rpm to over 3000 and then plateus, which is a sign that it's too lean and will die soon. Which it did almost as soon as I cut the video. Further running without changing the LSN setting revealed that it would not transition, either smoothly or at all, unless the throttle servo speed was slowed way down. I consider that a failure. Keep in mind that this is with the LSN as rich as it will go while still actually running without loading up and dying, which it did when adjusted even 1/100 of a turn richer. In short, to a lesser extent it's the same behavior the engine was exhibiting when I was running it inverted with no regulator on it. However, now the tank placement no longer matters, and it behaves the same no matter the height of the tank or the fuel level, which is at least an improvement, if not the one I wanted.
I think this engine has something fundamentally wrong with it that doesn't let it run inverted. It was suggested to me last time I was out flying with folks that the engine may still not be fully broken in yet, however I probably put about half a gallon of fuel through it both on the stand and flying when it was side mounted, so it's probably loose enough now. That was my last idea as to why it doesn't work inverted. I'll admit defeat at this point...
This is what the regulator installation looks like. I mounted it directly behind the engine, on a plywood brace, with a 1/16 inch thick section of fuel tubing on the screws in between the engine mount and the regulator mount. You always want to soft mount something like this, as these things have very delicate little components in them that will easily become screwed up by engine vibration. The plumbing setup which before was rather straightforward has now become a disgusting mess - but, due to the tank pressure system, both lines to the tank now need a T-joint and a corresponding plug for fuelling/defuelling.
So this leaves me with the question of what do I do now? Obviously, if I want to build realistic dummy engines, keeping the current engine is not going to work. Additionally, I am not sure how many 4st glow engines will reliably function inverted at idle with no glow heat applied, while also fitting in the cowling. I know from experience that a Saito 56 will do it marginally better, however that comes with the problem of the entire cylinder head sticking out of the bottom of the cowling, which I don't want to do. From measuring someone else's engine, a Saito 45S will fit, however the engine on it right now is already edging on underpowered, and an even smaller engine won't help this. I believe the 45 and 45S were also never sold in the US and so finding one of them is incredibly hard. I did think for a second that perhaps I could use a YS FZ53 since they both have a pump and regulator system built in, though I don't know if that would work either since I already tried a regulator system on the current engine with little luck. Also, this engine will not fit either, as it's taller.
Should I give up on inverted engines I have some more ideas. One, the obviously most expensive route, is buy a twin. This has the advantage of instantly making the airplane 100 times cooler plus negating any need for nose weight. They also sound really cool. My ideas for which engines here were the Saito 60T and 90TS as stated earlier, and I think I'm gonna go with the 90TS because some consulting of the user manuals revealed to me that the 90TS actually weighs
less than the 60T despite being 33% more displacement, and as such appreciably more powerful. Speaking of power, the 60T would be woefully underpowered, so much so that it's not even worth discussing, while the 90TS would have a little more power than the current engine, though surprisingly not a huge amount more. I get about 4.5 lb of thrust out of the current engine, on a 12-6 at 9500 rpm, which is fine-ish for a 7 lb plane as long as you never try anything stupid. I lack personal running experience with any Saito twins but I know a guy that has a few and he said that his 90TS will spin a 14-6 at about 8000 rpm, which according to some crappy math should make about 6 lb of thrust, give or take a few ounces depending on the propeller used. I'm not sure about running a 14 inch prop on this plane, though I'll test fit it on the current engine once I get home to see if the clearance is okay. A 13-8 would probably be enough load for the engine, but that might be a little steep.
Another idea I have is instead of buying an actual twin, just build a fake one. This would be a hell of a lot cheaper as well as negate the need to buy another engine. I figure if a twin is an acceptable appearance while not being totally scale, and a side mounted single is basically just half of a twin, just build a fake cylinder to the exact same dimensions and appearance of the actual engine, and then just mount it on the other side. It would be a lot less cool than an actual twin, and getting a convincing metal finish on balsa especially for an engine is quite tricky, but it could probably be done. Though, I've been given an excuse to buy an actual twin cylinder now, and I believe not using it is a crime against humanity or something
