Guinea pig good first plane?
Rhaps
Hull sides:
The sides should look like this - check that you have full cuts on marked place (I tend to forget those and have to add them afterwards)
Also remove paper from the very end of the tail and very moderately crush it
Fold and glue. Well.. technically glue and fold. Try to align the bottom wing slot as well as possible. Choose your glue wisely.
Once the glue has cured fold the sleeve on the nose and bevel diagonal edge.
Rhaps
Time to make couple of jigs
Then again...
These don't have to be pretty but try to line the sides as well as you can, that way the hull will be square.
You can test fit these to the hull sides, but there will be couple of more steps before these are put to use.
