With limited space in my garage, I store fuses and wings seperate mostly by attaching 1x4's to the wall that have half inch holes drilled in them which I glued dowel rods into. Spacing appropriately for fuse and wings alike. For heavier planes I had to put bracing under the dowel rods but was just extra wood cut. Originally I would just slide the whole plane on the dowels, fuse attached tail pointing out. Later, as I needed the room under the tails, I would sit the fuse sideway on the dowels with the wings stored above.
Presently I have my Flite Test foamies hanging in my Bed room using coated copper wire used in flower arrangements and picture hooks. They all weigh less then most frames I've hung. I know, a 50 year old man with airplanes hanging in his bedroom. Well, it WAS my son's room all his life till he moved out and I just hung my hammock there so my snoring rearend wouldn't disrupt my wifes sleep. Maybe I should have put a comma in there as both sides do bother her at night.
Kinda reminds me, I do need to clean out my garage.
