Headbang
Key to using gorilla glue is to make sure you have tape, rubber bands and various heavy objects handy to hold the parts in place ahead of time. Using white gorilla it take 30mins to an hour to setup. I tend to do all the parts I can at once, then walk away for a few hours. Another thing I have learned is the value of making pin pricks in places where you want strength, it gives the glue a place to expand into to, creating almost a glue nail. Biggest advantages are weight and sanding, you can really clean things up with some 240grit sand paper and make a pretty plane.How does the build process go with gorilla glue vs hot glue? How long does it take to set?
I think we have all hit the throttle on the bench with the prop on. I did it with an 19x8 prop once on a DM4330-435 6S, it ate a castle programming cable, my shirt, and the tail of another plane. Unfortunatly over the years I have managed to rack up a lot of scars on my hands from props, and been where you are a few times as well. All while tuning or testing.
