Brand new to the forum and am just finishing my first FT plane. Never really installed or had to replace a propeller as usually do a lot of unpowered slope soaring, so these are complete newbie questions.
1) Are plastic spacers/washer needed to attach the 10 x 4.5 CCW to the Radial C motor? It seems as if the prop snuggly slides on past the threaded portion of the shaft, but runs into resistance where the threads stop. I don't want to force it further unless that is how you seat the prop snug up against the front of the motor.
2) Which nut should I use? The is a nylon lined lock nut or a spinner shaped nut with no nylon. I won't be using an additional spinner, is the spinner shaped nut safe with out the nylon lock liner?
3) Does the ESC have a way to program a safe feature so if the TX is turned on and the throttle happens to not be all the way down it will not immediately start the prop. Tested this on the Power Pack C with my old Spektrum DX6i and AR410 receiver and with the throttle stick at half way, the prop started shortly after I turned on my TX. Flew old park zone planes back in the day and they had a feature that required you to bottom out the throttle stick require to arm the motor.
4) I really enjoyed my building this first plane and ordered 2 more, one being the Simple Stick. Anyone fly this with the Power Pack C Power Pod?
Bonus Question: Do light coats of acrylic rattle can paint work on the new white foam in the kits (Krylon Fusion, Etc?)
Thanks for any help you all can provide!
