I got some problem when using Betaflight and trying receiver, I am not sure how to fix themðŸ˜.
First, when I toggle the left stick, the throttler raise so quickly to the limit I set and then become uneven after a while,they coub not even turn off! how can I let it raise up slowly, smoothly and trun off by toggling down the stick.
the picture shows the situation when I toggle the stick to max.
Second, motors 3 and 4 should armed when I toggle the right stick to right side, the order seems wrong and I am not sure hoe to fix thm. Hope someone can kindly help me with those problem. Thank you.
Betaflight
Taranis QX7
X8R reciever
Betaflight
Taranis QX7
X8R reciever
