help designing carbon mini quad to be sold for around $60
Hi my name is Luke I have been flying rc stuff for around 7 years. I am 16 and got into fpv around a year ago and I got my fist mini quad around July 2014. So I bought an emax mini quad and really like it but I have gotten pretty good at it and wanted something better and smaller because the emax quad is kinda big although you can use 6 in props. I had two options I could get a blackout or something like that or I could try to build something out of carbon. I decided to build something. I was thinking why do nice carbon fiber mini quads have to be so expensive the cheapest I know of that you can get is $100 so why not make something affordable and good quality also I spent nearly $200 in parts for the one I am making. I could of just got a blackout but now I can try sailing them as I have enough to make 4 quads and would get more stuff to make more quad if I can sail. So I received my carbon today. I bought one sheet of 1.5mm carbon for the main parts and a sheet of 3mm for the arms. I do a lot of designing on auto cad as my Dad has it for his work I have access to it
. So I spent a couple days while I was on vacation to designed a 220mm mini quad just small enough to fit 5 in props and carry a mobius. If this goes well and I am able to make some money on this I plan to make a 300mm mini quad. I plan to be sailing these on ebay at first and maybe get a website if all goes well. The reason I am posting here is because I need help finalizing the plans. Please do not hesitate to give your advice remember I am designing this for you all to buy so please any advice would be greatly appreciated. A couple of questions that I have are how do I know what size my mini quad is like 200mm or 250mm quad? I plan to mount the battery on the top plate with the mobiuse as that leaves room for the flight controller on the bottom plate and a video tx. Should I make a ccd camera mount like most quads have? I am going to use 36mm stand offs black I already ordered them. I will be using all stainless hardware and lock nuts. I am going to try to cut the carbon using a drimel drill press with a grout cutter bit any advice other than where a mask I already know that
. In the plans I have 3 different arm designed and I would like your advice on which one I should use or If I should do a total redesigned. The pdf I made is 11x17 so If you want to print it to get a good look at sizing you will have to have an 11x17 printer. I got my parts cost down to around $30 per frame and depending on how much time it takes me to cut out I will try to sail for $60.
the plans
View attachment mini quad.pdf
My you tube channel
https://www.youtube.com/channel/UC9B9SkoW6roKZ02VZNrOM5Q
video of me flying my mini quad
video of cutting carbon the way I am going to try.
https://www.youtube.com/watch?v=Sm7LTKsI8IY&index=5&list=WL
the plans
My you tube channel
