Techinator
So I can take off. But then when I go above or below mid throttle-ish, it decides to flip over. First I thought it was the gyro. Then the esc because I realized they had different versions flashed. Now I'm suspicious of one of the motors because it feels looser than the rest. But when I test the motors from betaflight, they all work fine, with very little vibration. I can only see the issue when I actually try to fly, not even with the props off from my tx. So i'm not even sure which motor it is, if thats the problem. (started happening after a very minor crash)
Thanks
Thanks
