Help to setup my v-tail
FatuloRacing
Hello;
It is my first time building a quad and I have problems with the setup...Im using Q Brain, KK2 Board for the quad and FlySky transmitter. I doble check the wires and I need second hand to help me to start. I don't know what happen if it is the transmitter setup or the connection in the kk2 so If some wants to help me I appreciate so much...
xuzme720
Dedicated foam bender
It looks like you only have one motor port plugged into the KK2. Is it the hub? That isn't used on multi's. Can you give us more detail on what and where you are hooking components?
cranialrectosis
I gotta say, as I look at the photos, I have never seen anyone put the V-Tail in the front.
Dunno if it will work, but it is a novel approach. With the camera in the back, you will shoot bitchen 'tail gun' style video.
If you did not intend to put the V-Tail in the back, your KK2 board is backwards. You want the buttons of the KK2 in the rear.
cranialrectosis
Just so long as you know that in your photo, your KK2 is pointing to the rear of the copter.
I posted this while you were posting and before I saw the photos above:
What happens when you connect your battery to the power harness? Do you hear your ESCs chime and does your KK2 power up?
cranialrectosis
Have you zero'd out your subtrims in the receiver test on the KK2?
This establishes that the KK2 is receiving the transmitter's signal.
xuzme720
Use a normal x-quad setup in the KK2 menu. Try this vid, it goes through the whole setup.
FatuloRacing
I try the calibration in the kk2 and but full throttle on the transmitter and connect the batt and press the two bottoms for the calibrate but the final beat not sound...What now???
cranialrectosis
"and connect the batt and press the two bottoms for the calibrate"
You have to have the buttons pressed down before you plug in the battery. This is best done with an assistant.
Also, whatever you do, perform this step with the rotors off.
xuzme720
I just unplug the ESC from position 1, plug in my bat and push both buttons then plug IN motor 1 ESC. KK2 board powers up like you just plugged in the batt and its much easier to plug in a servo lead one handed than the battery.
FatuloRacing
Love you Guys!!!!!! Im finish now hooooooo!!!! Im so excited!!! Thank thank thank for your help and your patience...Videos coming soon!!!!!
FatuloRacing
The only problem I have is, to armed the KK2 with the FlySky transmitter you need to move the ail/thr stick to the right corner and is armed...
