Save/export Model setup
Sly Fox
So I have the FlySky FS-i6 transmitter. The data cable finally arrived. I want to do the firmware upgrade to make it the 10 Channel. Is there a way to save the Model setup I have already programed so that after the upgrade I can import them vs having to manually set them up again?
Foamforce
The link implies that you can’t transfer models. That seems likely since there isn’t any sd card slot or normal USB connection.
Bricks
As stated do not have that transmitter but if your data cable connects to your PC and you can open the radios files you should be able to find the model setup section. Copy this to a folder on your PC and after the update put it back in the models folder. At least that is how OTX and Edge work.
