Help to setup my v-tail
FatuloRacing
No throttle on the left and aileron right, Tomorrow install the propellers and fly test or crash test...Let you now later...thanks for hepl me
cranialrectosis
flips on startup.
You have likely:
ESCs connected to the KK2 wrong
Propellor upside down
Motor spinning the wrong direction.
Did you get the KK2 pointed toward the front of the copter?
FatuloRacing
Craftydan
Hostage Taker of Quads
Going clockwise, starting with #1 in the top left corner.
From the one prop I can see, # 4 is pointed in the right direction . . . the other three, I can't tell ;)
cranialrectosis
http://www.hobbyking.com/hobbyking/...2_0_Multi_rotor_LCD_Flight_Control_Board.html
There is a photo on this page of the KK2 showing the pinout (4th photo from the left). The ESC connected to motor 1 plugs into M1. The ESC connected to motor 2 plugs into M2 etc...
Usually when I cause my copters to flip on startup, I have motor 1 in M2 or something like that.
Motor one is top left in your photo. 2 is top right. 3 is bottom right. 4 is bottom left.
xuzme720
Dedicated foam bender
Check your rear motors and props for correct rotation. Looks like they aren't spinning in the right direction...
FatuloRacing
Im doble check and try to the oder side and I have the same problem, I don't know if I need to change something in the transmitter?
FatuloRacing
Im don't Know what happen I verify everything with the same result. I thing that I need to change something in the transmuter, put son channel in reverse or something like that but im not any idea. Im a litter frustrater but im going aging
xuzme720
Verify with the KK2 board in the layout menu that the motors are spinning in the correct direction, and once they are, make sure the props are correct and blowing air downward. In your video, it looks like the rear props are spinning in the wrong direction, blowing air upwards rather than downward.
cranialrectosis
That is a beautiful copter. I just got my Bat Bone and am thinking of building one of these.
If your motors are spinning in the correct directions and your props are blowing down, check your ESC connections to the motors and the KK2.
Do this with the props off.
Disconnect all your ESCs from the KK2. Find the connector for the ESC for motor 1 (the top left motor as the copter faces away from you). Connect it to port 1 on the KK2 (the port on the top right of the KK2). Really, take the props off. Arm the board and give the motor power (not full power). Does motor 1 spin and is it spinning the right direction? Once you are satisfied that you have the ESC for motor 1, label its servo connector. Disconnect ESC 1 and connect ESC 2 on the pins for ESC 1. Arm the board and give it some throttle. Does motor 2 (top right of the copter) spin? Does it spin the right direction? Label its ESC at the servo connector.
Repeat this ONE ESC/MOTOR AT A TIME until you have labeled your ESCs and can connect them in the proper order to the KK2.
If these steps don't fix it, then we start looking at transmitter settings.
ESCs connected wrong caused me a whole day of frustration two weeks ago. It gets most of us at one time or another. Hang in there a bit longer.
