Anyone have experience with the DEVO 7 Transmitter and setting up plane with inboard flaps and retaining individual aileron control with out use of "Y" harness?
I've been battling getting it set up and have almost got it, but can't seem to find way to adjust the input of the FLAP points for each position of switch.
Also I can't get my mixing to work with the inboard flaps with elevator.
I did have everything working perfectly as a Aileron/Flapperon plane, but then decide to switch over to separate flaps and I've been battling the Transmitter programing ever since... I'd love to get it figured out if anyone knows.
I've read that vag manual about 50 times now but it's the worst written manual ever. Vids search on google is also very poor in reults. Most the vids are for drones and heli and/or are just plain terrible for instruction.
My setup request is Super simple. I have an airplane. Ailerons were set up as Flapperons. It worked perfectly and decided to make life difficult and make separated dedicated flaps and ailerons.
I have each Aileron in its own channel. Right Aileron in channel Aileron on Rx. Left Aileron is Aux 1. Two servos connected to "Y" harness for FLAPS in GEAR channel.
Elevator in Elevator channel etc...
Right now, I have ailerons working and can adjust them individually by Tx and they work as they should, but do not have any control over using them as additional flap. The are connected to MIX switch. If I flip switch up or down it does the same thing as the flaps with it's poition points.
As for the FLAPS I have them connected to FMD and they go from -62.4% to 0 to +62.4% making it look like they are working with the switch but are not adjustable for each position.
1. Should I be using the Aux 1 for second aileron or should I be using Aux for Flaps only.
2. Should I be using MATE for having left aileron work with right aileron? or some other way to have the left and right aileron still function as a flapperon?
What I would like to have is Ailerons to work as Fapperons on FMD or MIX switch and my dedicated inboard FLAPS to work off the FMD or MIX switch and be able for me to customize how much flap down for each position be adjustable.
Is this possible? who knows how to do it?
