Hello,
I'm just finishing up a flying wing I designed. I just picked up a new Spektrum DX6i and I'm having trouble figuring out mixes. Its a traditional elevon setup however I have drag brakes on each wing (similar to the B-2), each with their own servo. How do I setup so that when left (or right) rudder is applied on the stick only one servo operates? I understand differential for the ailerons but how would I apply this concept to the rudder stick?
Currently if I push Left (or right) on the stick the opposite side (which is fully closed) attempts to move past fully closed and strains the servo. Any help would be greatly appreciated,
Thank you,
Adam
Example of my setup.
http://static.rcgroups.net/forums/a...External Drag Rudder Linkage.jpg?d=1252864606
Thank you,
Adam
