How to hook up muffler?
jakexie6
This is a dumb question but I was wonder how do you hook up the muffler to an engine? I know you need to bolt it on but I see a little tap that looks like it's meant for a hose or something. Leave it empty or am I supposed to hook it up somewhere?
Joker 53150
Mmmmmmm, balsa.
Normally a fuel line goes from the muffler nipple to a line on the fuel tank. It pressurized the tank to help provide constant fuel flow to the carb.
Bricks
I take it you are running Nitro as gas gets set up a little different. It can be done 2 different ways 2 fuel lines or 3 lines. Two line 1 goes to the carburator and the clunk in the tank, the second line brass tubing gets turned upwards in the tank and hooks to the muffler, For filling you remove the line to the carburetor and use the muffler for overflow when tank is full.
3 line= 3 brass lines coming out of tank, 1 will go to the clunk connects to carburetor, 1 will be bent up near the top of the tank for overflow when filling tank, will go to the muffler. and 1 will lead to the bottom of the plane for filling and needs to be plugged when running the engine to use muffler pressure to feed the engine.
SlingShot
Maneuvering With Purpose
Does it matter which line it is connected to or can it be any?
The suction/clunk line goes to the carb. The vent line goes to the muffler.
Instead of having only straight suction, you get tank pressurizing from the exhaust gas.
