I appear to have made a thing
rockyboy
Skill Collector
Very neat little build! Does it glide OK? It looks like it might be very sensitive to CG placement, but the motors should be in the right spot to give you decent altitude and yaw control :D
Now I want to find some little styrofoam plates too... :unsure:
CarolineTyler
It glides okay, I taped the various bits back and forward whilst doing test glides until it was looking ok. Only then did I stick the bits down. Tried turning the plane last night and its going to have to be quick nudges left or right or the plane rolls over and dives! Challenging to fly :)
FDS
You could try putting more dihedral into the wing whilst weather is horrible, that might help the stability. Extending the tail plane up and over the wing might help too.
It looks like a paper aeroplane!
CarolineTyler
The paper aeroplane was the aesthetic I was going for!. novel and fun way of using scrap foam bits and a semi broken toy whoop sized quad ;)
PsyBorg
Wake up! Time to fly!
#19
Would winglets help? If I am thinking correctly they help with that whole dropping a wing thing.
Also maybe adjust your end points so when turning or banking one side throws less then the other. I believe the low side of the turn gets less throw.
CarolineTyler
Adjust your throws, on this???
It's just a toy! Lol
8th December - Leeds University hall...maiden!!!
