jpot1
In fairness to you, it was not your design that was the issue. It was all my own fault. I took your design and built it a little bigger and my pod was not exactly the one you made either. I had trouble getting the CG in also because I was trying to use an 1800mah battery at first--no go!! I switched to a 2200mah battery and did several test glides until I got the CG. It was very sensitive to CG--there was one sweet spot and about 1/8 to 1/4 fore and aft movement of the battery and the thing would not want to fly---too pitchy!! Not used to this tight of a CG on a wing, but then I have many wings but no power pods attached--just reflex in the elevons for compensation. Anyway, I also made it a pure KFM airfoil (not a big fan of them) because it was quick to build /prototype it that way. I am going to build a real airfoil version a little larger as well because I believe it will fly even better!!
I have built your some of your other designs and they are all great flyers!!
