Got all the patterns cut out today and stuck on poster board this morning, I'm gonna head to the hot wire this afternoon and knock a couple kits out.
Quick question, where did you put the lines that run down the wings for the wing camber?
Getting there! I hope to maiden in a couple weeks! Everything has been pretty straightforward so far. The wings were a little tricky, I had to come up with some wedges when glueing the airfoil into shape. but it's a pretty tight model so far. View attachment 67272
I've built two last weekend, one for my girlfriend and the other for me. If you built flite test models before, it's pretty straightforward. The only problems I had was getting the wing put together, on one plane I built them separate, and then stuck them together. That was a little tricky (for me anyway) because they didn't exactly match up as exactly as I'd liked.. On the second plane, I glued the two wing halves together then folded and set up the wings. I thought this worked much better for me. Other than that, this plane was really well designed and has been a lot of fun to put together. Once I have all the parts zipped out, it came together pretty quick. Oh also, Don't glue any of the top decking of the fuselage on until your rudder and elevator servos are set up. I guess I got excited and did that on one of the planes, and I had to cut it out. LOL
Great tips/feedback. Do you think the two wings not matching was a problem with the plans (shouldn't be since its just the same shape flipped)? I hand cut my planes and the two wing halves are never exactly identical. It sounds like attaching them prior to folding is the way to go.
That's an important note about installing servos before securing the rear deck. You could make a score cut for a hatch if you think you'll need access to them again.
I'm excited to hear how they fly! That sounds like a great motor/battery combination. It can easily carry up to 3S 2200mah if you want longer flight times.
Thanks for the info! Is there a wing spar that I'm not seeing?
No, no wings spares. I suppose you could come up with some, but the wing seems pretty strong without em'
Okay thanks! I am actually building this plane for a older friend of mine and he has a little time on a gas trainer but wanted some thing a little easier to fly at the local park. Will this plane be okay for him or is it still in the beta process? The parts I plan to use are a 39g 2822 1200kv with a 9x4.7 sf prop and a 2200 mah 3s.
Thanks for all the feed back!
Okay, thanks a lot!
