I just got back in to RC after 25+ years (wow how things have changed ... for the better!) and have been having a blast with the foamy "thing"! I was using an old flat closet door for a table and cardboard under my foam to protect it while cutting/building. As I went along, the cardboard got rough and had to be replaced often. Then I started running out of good smooth cardboard to use.
Being the "Cheap-o" that I am (with a capital "C"), everytime I went to price "real" cutting boards (are they expensive or what?), I couldn't make the "connection" between hand and wallet to purchase one large enough to be useful.
One night in the garage I happened to spot a stack of left-over laminate flooring boards. (You know, the boards my wife tried to get me to throw away a gazillion times because they were just taking-up precious space in the garage!) I put together about 4 of the boards which made a very nice and smooth work surface about 30"x 50". This particular stuff is Armstrong and is as tuff as nails. I try to be careful, but occasionally I've gotten through to the laminate surface with the Xacto blade. So far I have seen some very fine scratches which pretty much disappear with the wipe of a finger. Nothing yet that would cause any problems to the foam.
Anyway, I haven't seen anyone else mention using laminate flooring for a building surface/cutting board. Maybe some fellow "cheap-o's" might have some laying around, or could pick-up some left-over pieces or samples at their local flooring store for free or cheap. So far it is working beautifully!
Maybe this will work for someone out there!
Walt
Walt
