Hi Gang.
I'm needing to tap into this brain trust a bit, hoping you guys can help me out.
I've built a few SeaDucks, and have a great feeling for how twin electric motor flight feels at that scale.
Also I just purchased myself a Lazair series II ultralight this week, with the aim of swapping out it's twin 2 stroke
9.5 hp engines, with 2x 10KW brushless motors and as much LiPo as allowable, which I've calculated to be (to meet the regulation of 5 gal limit by volume, so 12x Turnigy 20,000mAh 6s, operating at 24s, 88.8V.
So given those constraints, I'm wondering if folks have any suggestions about what manufacturer I should be talking to in Shenzhen. If there is a North American dealer in agricultural drone motors. Is there a problem with my math?
So What are the reasons for this conversion besides the fun and challenge of a build?
1. Just Cool. Will sound like a starship.
2. More Green. These 2 strokes are tuned to run forever (lots of lube), which means they belch a lot of fuel from the naked carbs. Spooling up from idle to full power seems to take forever as super rich carbs bog etc. Soooo much power wasted in noise and vibration.
4. The engines are Rotax 185's which are no longer built and no available parts. The Airframe still has decades of life left, but these engines are obsolete. To keep it flying have to look at systems that use the latest technology.
3. 2x 2stroke pull-start engines are dangerous to re-start in the air. The Lazair has so much wing that it can soar with engines off, but re-starting the pull-start engines while in flight is dangerous, strenuous and prevent many from flying this plane. My aim would be to make this plane flyable by a Senior citizen, smaller person who lacks the arm strength who wants to soar quietly with geese, but have power on demand.
5. Yaw Stability. This plane has 2 factors that could be assisted by a gyro. 1 The Lazair uses an inverted V tail. 2 It's a tail dragger that is difficult to control at taxi speeds less than 10 knots as the 2 gas engines often run up to speed differently and the tail wheels can get caught and cause a sudden turn in early takeoff. So to smooth out these issues and make those takeoffs feel like you're on rails I want a gyro.
6. The designer of this airplane has already converted his personal Lazair to Electric almost a decade ago, and used it to make the first ever electric water landing. Really more than any air frame, this one is begging to be electrified.
Thanks for reading this post and please add any suggestions.
Thanks.
Christian
Thanks.
Christian
