Bernie---OH
First Post - Newbie
My ESC fried when I was testing electronics.
I bought the FliteTest Swappable "package" from Lazertoyz -
1) FT Swappable planes
2) FT Swappable Electronics
3) Radiolink T6 Transmitter/T7eh receiver
=== The Electronics included:
(1) Lazertoyz Blue Wonder 2712-12 brushless motor
(1) 8mm Aluminum Motor Mount
(1) Prop Saver
(2) 8x4 props
(1) 10 Amp ESC (this is all you need will only pull 8 amps)
(2) Emax Budget Servos (1 plane) , or add the 4 servo option, this gives you 2 for each swappable.
(1) 850 mAh Lipo11.1V 3 Cell - 25C discharge and 5 C charge rate
(2) EZ Justers (for EZ pushrod adjustment)
I built the power pod, plane, and connected all electronics.
- Motor, ESC, 2 Servos, and Receiver.
***** NOTE: I was warned and made sure no WIRES were touching (no short circuit).
Tested this on workbench (i.e. Kitchen table) - prior to first flight.
All connectivity seemed stable.
Servos worked, Motor worked.
Testing continued, all of a sudden, I saw a glow and smoke. Saw that the ESC was fried/melted.
QUESTION(s):
What would cause this? Revving the motor to high in combination with the servos?
I see that LazerToyz supplies a 10AMP ESC - I notice that FliteTest recommends an 18AMP ESC.
(1) Prop Saver
(2) 8x4 props
QUESTION(s):
