Solved LED strip not working in betaflight
Superman11497
I recently just built a freestyle quad with a SkyStars F722 mini HD Pro flight controller. This FC has 4 designated pads for LED strips and even shows the led strips in the setup guide for the FC. However when I plug the FC into betaflight and turn on the led strip in the configurator tab then hit save and reboot the led strip tab turns off again. Running betaflight 4.4 on the FC. Does anyone have any idea on how I can fix this? Anyone else have any issues like this?
Ryan O.
Out of Foam Board!
I’d follow this video’s process as close as possible, odds are that will fix your problem. If it doesn’t there’s some other troubleshooting we can do.
Superman11497
So it turns out I had the arrows on the LEDs pointing the wrong direction so I fixed that. However that doesn't seem to have fixed the issue with betaflight.
